How to bypass the security alarm for an autostarter?
Please, help me fulfill my dreams of get my autostarter working.
I just need instructions or "How to do" to bypass to car's security alarm. Any help is greatly appreciated. sid |
Howto steal an SVX
It looks pretty straightforward on the wiring diagram.
The security module controls a relay to interrupt the starter circuit. This relay is located up under the dash near where the wires come through from the engine compartment. It's a 2x2 connector wired as follows: Pin 1 Blue/Red is the power to the relay coil from fuse 23. Pin 3 Blue/White is the other side of the relay coil connected to the security module. The module grounds this wire in order to close the relay, which connects pin 2 to pin 4 and thereby enables the starter. Pin 2 Black/White is the power supply for the starter. Pin 4 Blue/White goes to the starter via the Park/Neutral switch.
b3lha,
Thanks for your help and I let you know how it goes. sid |
Hey,
the guy (who fixing my alarm) says I need the override the security module bypass. He said that that information I got is relay starter bypass. Please, help again and thank, sid |
Sid, take it to someone else who knows what they're doing before it's too late. If he works in a shop, they should already have access to the necessary wiring info for the alarm module. If he doesn't, then the pinouts are printed right on the security module itself. The SVX security module is about as straight forward and simple as it gets. If he's trying to do this blind, then he might just screw up your car before all is said and done.
KuoH Quote:
Thanks, Kuoh
sid |
