If a person has the funds to build a custom 3.7 stroker engine, I feel he would invest a bit of time and money in the induction hard parts of the engine. Ported head ports with bigger valves, improved intake manifold flow, bigger cams, ect. This being said it is not unreasonable to assume the engine would make 300 hp NA. With 300 NA hp it should be theoretically possible to make the hypothetical 700 hp on only 20 psi of boost with properly sized turbos and a good aftercooling setup. Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR* 1977 Ford Pinto baby blue with 79,000 miles |
I am just talking power here... it isnt my job to get it to the pavement
Jim
I have read of guys who are putting donw 650whp in STi's that have a stock tranny. Granted the STi is 400lbs lighter
I think that 500whp is conservative in our case... or reliable if you want
Why not an auto tranny? Oops! I'm getting off topic. Will be interesting to read more info about this setup.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
What setup?
That setup!
Close, but no seee-garr!
The set-up you mention will make around 630 hp at 20 lbs, assuming the turbos are big enough to deliver the airflow like you say. To see 700 hp with such a set-up you would need 24 lbs boost.
I still think that a 3.7L stroker kit will make the walls thinner and unable to handle that much boost... Unless... something really crafty is done to strengthen them from the outside...
Wouldn't "stroked" only affect the crankshaft, rods and pistons? Why would the walls be thinner?
No Danny, in a stroke job [can I say that on here??] the piston and the bore remains the same. It is the crankshaft that is worked on to lengthen the stroke of the piston, the distance it travels top to bottom. Longer travel gives the extra displacement. In a rebore situation the thickness of the liner comes into play. Joe
#28
OK... are we talking crank or wheel hp here?
Jim
#29
Oh sh!t.... I know the difference between stroking and reboring... I dunno why I thought of reboring when I read stroking... I think I need a or a good night sleep
#30
From what I've seen of the EG33's engine block, the open deck design may be the limiting factor in boosting it. The cylinders in an open deck block tend to "squirm" under boost. "O" ringing it will help, but to get the numbers you're talking about, I'm not sure that'd be sufficient.
Yes stroking the EG33 would only involve the crank & rods. The $64 question is, where would you source the crank? Are you saying that the Porsche engine has the exact same bearing spacing/diameter? The thoughts of an EG37 are VERY intriguing.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
