Old 12-08-2005, 08:30 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Tranny whine, AWD not always engaged
During the snow tonight, it felt like my car was only fwd until almost flooring it. I would spin for a few seconds then awd would "engage". Also when I'm spinning I hear a whine from the front somewhere.
Brian
Old 12-08-2005, 09:26 PM
Manarius's Avatar
Manarius Manarius is offline
I bet your clutch packs are worn out.
-Jason
-Obi Wan Kenobi
Old 12-08-2005, 09:51 PM
Ricochet's Avatar
I brought some ham.
Where are they and how hard are they to replace?
Brian
Old 12-09-2005, 11:53 AM
Earthworm's Avatar
Meow!
It's either the clutchpack or the duty solenoid sticking/failing. Either way both should be replaced. All are in the transmission extension.
Old 12-09-2005, 12:46 PM
Ricochet's Avatar
I brought some ham.
Got a picture and/or part number?
Brian
Old 12-09-2005, 01:06 PM
Manarius's Avatar
Duty Solenoid wouldn't whine, I think. I could be mistaken however. Usually, they just crap out.
-Jason
-Obi Wan Kenobi
Old 12-09-2005, 01:38 PM
Earthworm's Avatar
Meow!
I never said it would but that's one cause of a malfunctioning AWD.
Old 12-09-2005, 03:23 PM
Manarius's Avatar
Yeah, Duty Solenoid C and Clutch Packs are the two most common problems when AWD starts crapping out. Sometimes it's a bust TCU as well, but that's not as common.
-Jason
-Obi Wan Kenobi
Old 12-09-2005, 08:37 PM
oab_au oab_au is online now
Transfer problem.
Gid'ay Brian, As the transfer clutch does engauge,eventually. I'd say the transfer valve is sticking, may not have had to work for a while. I'd give it a while to see if it frees up and fixes itself, as it works. If not it will have to be renewed.
The whine from the front could just be the differential gears, as one wheel may just spin faster that the other. If it is ok when driving normal, thats what it is, so don't worry about it, its normal.
One Arm Bloke.
Tell it like it is!
Old 12-10-2005, 02:31 AM
Ricochet's Avatar
I brought some ham.
So just keep driving it to see if it fixes itself.. well since that sounds like the cheapest fix I'll try that first
Brian
