Tyres
Thank you to everyone at the JAE who pointed out that my tyres were looking a little worn at the edges. I went out this morning and bought two new Falken ZE512's. I've been using these for a few years now and they are a really good tyres. The best part is they are only £55 each fitted.
This afternoon I plan to change my transmission fluid because it's been about 18 months since it was last changed and it's starting to smell burnt. Phil.
Other than checking the level, can you tell exactly where the leak originated?
It could have came from a breather hose but it could also be from the steering system or one of the transmission lines.
It's oozing out from the seal where the front pipe joins the gearbox. I drained out a cupfull of fluid and now doesn't leak at idle. But it is still leaking when driven. I find the trans dipstick useless, it always has fluid smeared along the whole length - impossible to read the level. I always try to measure the amount that I drain out and put approximately the same amount back in. It normally takes about 5 litres (which means there is another 4L of dirty fluid still in the trans somewhere!). I might drain a little more out and if that doesn't work then I'll change the seal. Phil.
Phil,
Did you get everything tight after changing the oil? Did you remove the pan or just the drain plug? Sometimes the PS fluid will leak on the pipes. Funny that should happen the day after a trans oil change. Quote:
Phil,
You should change all four tyres to reduce any chance of harming the trans. It is worth it in the long run. Quote:
On the exploded diagram, there seems to be some sort of spring and ball valve surrounded by a couple of fibre washers. It looks pretty simple to change the washers. Quote:
Phil.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 08-03-2006 at 02:30 AM. |
Congrats and heed the 4 Faklken advise-they are on 3 of our 6 cars now and THE current bargain in the tyre domain. If they said Michelin on the side-they'd be 90 quid per.
Sold-Black 97: They're All We'll Drive-into the side of a Pathfinder that lost it's path! 2004 Stage 3 XT Forester-Soon for sale! 2007 Jag S-type, just 17k on it! Past prides: 1992 black LsL new off the lot. 1992 pearlie for a few months. |
Yeah, I'll be getting a couple more tyres after payday. I'm driving my legacy at the moment anyway.
I found the problem with my leaking trans. The hose for my trans cooler had become kinked and was restricting the flow. I don't understand how that happened, but I've rerouted the hose now so it can't happen again.
Good job Phil!
I'll be sending you a note later this week. Quote:
