Headlights not switching between hi and lo beam.
The switch appears to be fine.
It is turning off the foglights and the blue light for hi beam switches on and off like it should. I swapped a few relays and it appears the relay is fine also. What should my next step be? I recently changed the starter relay under the steering colum and did the alternator wiring upgrade. |
Re: Headlights not switching between hi and lo beam.
Are just the low beams staying on? With the high beams on, the low and high beam bulbs should light up. It sounds silly but did you check if both high beam bulbs are burnt out?
No. I did not check to see if both were burnt out.
I thought no way. But I will. |
Well... damn.
It appears both bulbs are burnt out. They both have 12v when turned on. |
Check the high beam relay again. Harvey.
So does that mean I need to still check the relay? |
