HID lights
One of my HID lights failed last night . When I turn them on one does the slow warm up the other flickers and dies . I disconnected it and I am running the original bulb for now . ($125 fine if a LEO sees one head light out ) Too cold to fool with it now . Most likely I will change out the whole system . Any idea what is wrong ? Can Cold weather effect it ?
Re: HID lights
sounds like the ballast is bad to me.
Re: HID lights
I agree. That sounds like a bad ballast.
Re: HID lights
I am now driving around with one hid and one normal
Re: HID lights
Conn, just buy a new kit
1995 POLO LSI 76K MILES SOLD |
Re: HID lights
and pay more than $19.99 for it !
I've had my Lavalux HID's in my low beams and fog lights since 2007 and never had a bulb or ballast problem. But then I paid $199.00 for each kit back then. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-31-2011 at 09:34 AM. |
Re: HID lights
If you want the most light, get the 5000k I would personally stay away from anything higher than 6000k. You would look like a ricer with those annoying blue lights that make very little lights
Re: HID lights
I think 4300k is pure white and the most light period. 6000k will have pronounced blue and looks nice. any more and you get too much blue and not enough light. and if you have 55w bulbs you can use them with 55w ballast only. you can however use the 2 bulbs you have with new ballasts the only thing I wouldnt do is use a new and an old bulb together. The bulb changes color slightly as it ages and if you have 2 different aged ones they may be noticeably different. Last edited by 92 SVX; 12-31-2011 at 06:42 PM. |
Re: HID lights
55W verses 35 W why go lower Watt .What is the advantage?
Re: HID lights
Basically, 55w = high beams, 35w = low beams
DDM site says: "Due to the power of the 55W ballast, the output is slightly washed out as seen above. The most popular color we sell is 6000k. That would be described as white with a hint of blue. For maximum visibility, we would recommend staying within 4500K-6000K." So running a 6k blub on 55w ballasts will wash out some blue the color and look more white. I have 55w DDM ballast, mine looks like this one: We think that the bulbs are 5K. but we are not sure, there are no markings. Either way, once they are fully powered, there is no hint of color, they look white. That silverstar in the video is a modified 9005 high beam light in my low beam socket, and the 55w HID is MUCH brighter. Last edited by Lookin4SVX; 01-01-2012 at 06:48 AM. |
Re: HID lights
I think I will stick with what I have 55W 6000K low beam .
Now I have to find a good place to order them from and wait till the weather warms or find a heated garage. Just removing the old ballast and putting in the reg. bulb i froze my hands off. |
Re: HID lights
Hard time getting a good picture , it is behind the battery
Re: HID lights
That's the shift resistor for the automatic transmission.
I remember mounting the ballasts under the head lights. Like inside the bumper. I dont think I moved them. If you follow the wire back from the bulb you'll get to two connectors where you can unplug the bulb. Keep following the wire back to the ballast.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page Last edited by AFBeefcake; 01-01-2012 at 08:39 AM. |
Re: HID lights
You should probably send that to OT. He's been short on those because no one sends the cores back to him.
Re: HID lights
Thanks I thought that was strange that I found one and not the other .Also it didn'look like any I saw
