Recommended maintenance: Replace vacuum hoses at 100K miles
I decided to pull of the intake manifold to make it easier to replace the PCV valve and knock sensors, and so I decided to do all vacuum hoses too. Glad I decided to go that way. Virtually every hose had hardened to the point of being almost non-flexible. I suspect that many of the hoses would have started leaking vacuum within the next 20k-30k miles. .
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by svxcess; 03-20-2019 at 01:16 PM. |
Gee, I will have to go out and check mine.
How many can be replaced with standard hose and how many need to be the OEM pre-bent hoses?
Doug
I think that all of the vacuum hoses could be replaced with straight hose, but it would be necessary to get high quality hose that's got the proper metric ID. I tried some 1/8" vacuum line I picked up at Schuck's, and the ID was too big for a good seal. I'd probably go with viton hose which has a greater heat range than standard nitrile rubber and can withstand gasoline fumes (unlike silicone hose).
I don't have to go under my hood to know most of my hoes are hard as rocks.
I replaced all mine a while ago with just bulk straight hose. You don't need the pre bent hose as long as you can remember which hose hooks to what terminal.
Almost all of mine were dry and brittle. I'm sure I was losing vacuum with the condition they were in.
Gee, what a surprise that the lines were rock hard Can you post your source for viton hose when you find it? Thanks. -Bill
http://www.subaru-svx.net/photos/fil...czko/29136.pdf
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 09-05-2005 at 10:40 PM. |
