cv joint boot ripped, oil everywhere???
ok so i get under my car to change the thermostat and i notice my passenger rim is coverd in greyish oil, olong with the caliper and stearing ect. so i found out wfter taking off the wheel my cv joint boot is ripped but what is up with the oil??? arent they suposed to be dry??? and where is the oil coming from? can i drive the car with it ripped?
The boot is there to retain the grease in the CV joint...once it rips, it slings out the grease...you can drive it like that for a while, but need to replace it as soon as you are able.
how hard of a fix is it
Good luck! |
I've changed out several axles....
And I can do one on a SVX in about 30 minutes.... But for a first timer, expect to waste an hour, to 2...just because you will be running back and forth for tools, you didn't know you needed.... It can be done by removing 7 bolts/nuts, and driving out one roll pin
Rebuilt with lifetime guarantee is only about 60 dollars
Exchange at Napa I replaced mine by just the one that holds the spindle, not the three in the ball jount (edited) Sorry forgot to take the wheel off! TY Huck. lol Tapping out the pin but you need to be real careful. Reinstalling the pin can be tricky as there are two different ways to put the replacement cv shaft on. be sure and do it right so the hole for the pin is properly aligned. It can look right but not be and the shaft has to be pulled off and rotated 180 degrees to be correct. If it isn't right the pin cannot be driven in and could be a disaster to try to force it in.. the pin also has to be driven out the correct direction when removing it. and the new pin the correct direction as well. If you get in a bind, come back on the form... lots of good people to help you!!
Good luck!! Keith Last edited by kwren; 08-01-2007 at 12:31 PM. |
Is the Oil black cuz if it is I have the same thing wrong with my. I have been drive my car just about every day cuz of work and the car feels fine but when I park the car and take a look at the wheel it looks like if I just got done doing a big asss Auto X cuz smoke is coming out of just that wheel
So over all what would we have to get new? I already have 3 job dam I new one more just to keep this car going. Also have you had any thing wrong with your power steering hoes or links? Can anyone show me what part it is on like subarparts.com So i can have a pic of it?.If you want I can get some pics of what yours and my car look in the wheel. Have to wait in till my bro gets back he is drive my car when his sti is in the shop.
It's a front axle. It's not a big deal. Most any autostore can get one for you. I got one with the lifetime warranty.
one quick question if i pull the axel will i loose all my gear oil(i have a wrx 5 speed , if it matters)
How much will it cost for a shop to get it in. Also how much would a tune up for a Svx cost form a dealer ship? (spark pulgs, all new brakes fluids,read Diff,trany, and coolent.
