Old 03-27-2015, 12:39 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Re: Unexplained battery drains
Is that the click click issue? I always thought it would actually click as though it were trying to engage the starter but didn't have enough juice.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 03-27-2015, 03:06 PM
Ronald6 Ronald6 is offline
I'm having the same issue halistan is having. I turn the key to start. All the lights work, the fan clicks on and the antenna rises as the radio turns on. But not even a click from the starter. I few more tries, the amount varies, and the car starts as strong as ever. I've had the "click-click" issue before with other cars. This isn't that.
Old 03-28-2015, 05:23 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Try taking a voltage reading at the starter solenoid while turning the key. Probably a bad connection somewhere.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 03-28-2015, 05:26 PM
halistan's Avatar
Grand Poo-Bah
That's a good idea. I'll give that a try. You don't think it is the ignition switch getting worn out? That's what I've always attributed it to in the past, but if not that would be good as its expensive to replace
Old 04-05-2015, 07:41 AM
halistan's Avatar
Grand Poo-Bah
UPDATE:
Okay, with the help of Master Kuo, we think we found the culprit for my battery drain issue.
It seems that the hood sensor that we installed as part of the remote start/alarm was not getting pressed down far enough. When the sensor is not pressed fully, it pulls nearly half an amp from the battery (really high but it is what it is). When it is pressed securely like its supposed to, the drain drops back down to 40-50mha
In addition, we put on another relay to replace the starter interrupt relay and the car starts up every single time now, so that's good.
However, whoever it was in one of the threads that I read that replacing the relay takes 15 minutes is on crack. That was a terrible pain in the @$$ and I hope I don't ever have to do it again.
Old 04-05-2015, 08:49 AM
Glad you found the culprit, Ray.
Many years ago I started having weird electrical issues with my ZR1. Seemed to happen all of a sudden to a car that was electrically flawless.
The first words out of his mouth were: "If everything was working fine and suddenly you had issues that were difficult to diagnose, think back to the last thing that you did to the car ( whether a week or a month ago)"
I then remember adding an additional 12V power outlet in the hatch area. I had made a less than secure connection which caused minor intermittent shorting.
Fixed the faulty power wire at the outlet and everything returned to normal. That is why I have become so anal about proper crimping, soldering, shrink wrap, etc.
Old 04-05-2015, 08:56 AM
For another weird electrical problem I had on my polo. Read this thread:
http://www.subaru-svx.net/forum/show...per#post322733
And if you can't figure it out in the first 2-3 posts, scroll to post 15 for the answer.
A Subaru error, with a problem 10 years in the making. I would have never thought of this, and neither did the SVX Master Tech.
Old 04-05-2015, 09:02 PM
halistan's Avatar
Grand Poo-Bah
Nice! Glad you finally got that resolved. It's amazing that you ever found it with something that off the wall
What seems to have happened was when we installed it, I also had a hood strut that was backwards so the hood was skewed a little. I didn't correct it then and it worked fine for some time. A month or so later, when I corrected the backwards hood-strut it shifted how high the hood sat in that corner where the hood sensor was and made it so that it wasn't fully pressed.
I saw notifications on my remote occasionally that the hood showed open, so I'd go out and press it down a little and the notice would go away (or at least I thought).
As it ended up, the sensor would come up again and start draining power again.
Glad it's fixed now though. It was very irritating
