Sloppy mistake leads to cracked block
I am posting this hopefully as a learning experience for anyone that wasn't sure this was possible and maybe get some insight as to how severe this really is.
While I was tired and rushing I failed to clean all of the penetrating fluid out from the threaded insert for the head bolts. It seems I created a hydraulic pressure that split the end of the insert and relieved the pressure to the outside of the block. I finished installing the heads and the headstuds hold the appropriate amount of torque. It seems the crack is only from the threaded insert to the outside of the block. My instincts right now are telling me this crack will gradually get worse until the threaded insert pulls away from the block.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. Last edited by jman050; 05-17-2016 at 07:49 AM. |
Re: Sloppy mistake leads to cracked block
Any chance getting in there with a TIG might hold things together ?
That's what I'm hoping. My next day off I'm going to clean it up some more and bring photos to a welding shop and see what my options are. I'm sure it's possible to repair. I'd prefer to not have to strip it down to bare block halves again but not sure of the requirements for preheat for cast aluminum of that size.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
That would be an easy repair but you would need to have rubber and plastic items removed from the area for 6 inches or so. I've done wheels, blocks, propellers, boat hulls, heads etc and this looks like a easy fix to me. Good luck.
