tranny line ballbearings?
are there ballbearings in the tranny where the tranny lines go into it?
Re: tranny line ballbearings?
A little more detail please??
There are many bearings in the trans... AT or MT? Which "lines"??
ok its an at., original tranny.... there are 2 lines comeing down from the engine to the tranny, there are screws going through them at the tranny to keep them there, the one screw had a spring on it, and in the tranny where the line connects i think there should be a ballbearing but i dont know if both of the lines have one...or just the one with the spring? i was taking it out and a ballbeaing fell and i figured that that is where it was from
and along with that ball bearing i also have this spacer type thing that came out into the tranny pan when we were takin the pinion out idk if anyone could help me where that goes as well?
thanxs bobby 101_0657.JPG 101_0655.JPG |
the spacer thing you are talking about is a plastic ring that is broken in half? That is the thrust washer that adjusts the end lash of the whole rotating assembly. If it's fallen out then your end lash has increased by that much which basically sucks but there isn't anything you can do about it but drive it till it blows.
The ball bearing you are talking about is a check valve on the output line. There is only one. |
the washe is not plastic its metal....and it is not broken in half
wait, i just looked at the pictures...I don't know what that ring is..I don't think it's part of the transmission unless that's the washer that is supposed to be on the end of the pinion and someone somehow forgot to put it on and it ended up in the pan.
