First time at the drag strip, can some one analise my slips?
Last night i headed down to pacific raceways, for the open draging, i managed to get 4 runs in. From 15.924, to 15.504. My car is a 92 SVX, 5spd, 4.11 with a spec stage 3 clutch, header back exhaust, and a ecutune stage 1 chip. I pulled the spare out, and that was about all for weight reduction. My clutch was slipping throught 1st, and some of seconed for all runs. I would usally drop the clutch at 3.5-5K the lower drop netted my faster 60 foot times probley becasue of less clutch slip. I thought my last 60 foot was OK, but i would of liked to get down to 2 flat. The only thing that concerned me was my MPH at quarter seemened alittle low, i thought i was going to be in the 92, 93 range. It may of been becasue i had to either shift into 4th, or ride 3rd out to above 7k. The temp out side was in the low 60s so it was pretty good draging. Next time i go iam going to brind some ice to pack on the intake manifold to what times i can net. I was hoping for a high 14 sec pass, but it seems like iam pretty far away from that now.
Run 1 slowest r/t .619 60 2.415 330 6.744 1/8 10.315 MHP 69.68 1000 13.345 1/4 15.924 MPH 87.65 Run 3 fastest run r/t .745 60 2.234 330 6.465 1/8 9.964 MHP 70.88 1000 12.958 1/4 15.504 MPH 88.79 Last edited by svxsubaru1; 08-11-2005 at 10:25 AM. |
Not bad at all... With the temps that low in a 4.11 5mt you should be on the boarderline of 14's though. I think if you shift shorter than 7k rpm you may be better off. There is a lot of scratch over the scanners about the MAF maxing out of people at high rpms. This tells me that the lower rpm you shift at the better. I tend to shift just under 6k for my best times. A good launch is key also. My best 60' time was 2.02. Work on good shifts and good launches and you will be in the 14's easy.
Tom |
Nice times. The temps were pretty favorable and I agree with Tomssvx about being able to squeeze into the upper 14's. How badly is your clutch slipping in 1st & 2nd?
-Chike
Well, I used to do be able to do small burn out, but now i drop it, and no burn out, the clutch complety grabs by 3rd gear. It still grabs farley hard it just dosent complety hold it any more, when i launch. I was usally shifting at around 6200 RPMs, but one run i let it go all the way out to about 7100, so I wouldent have to shift into 4th, and the I ran a 15.7??, with a 2.4?? 60 foot, at 88.???MPH
Can you think of any easy, and cheap mods nthat i can do by friday. I was thinking of bringing some ICE to pack onto the intake manifold. Last edited by svxsubaru1; 08-11-2005 at 01:14 PM. |
nothing is comming to mind. You could pull the intake resonator and pop the cornerlight out while racing. Thats about it
Tom |
pull out the back seat and the passenger's seat - probably good for at least a .1 of a second....
-Bill
