help,turn key to start,no sound
my 92 svx happened from time to time,about 20-30% of time,
when i turn the key to start,all the lights show,but when turn key further to start,no sound at all. Before,i have to try again,and it usually starts after the 2-3 times. Today,i went up to the snow parking lot,0 degrees cel.,and take me 6-7 times to start. Is this the starter problem?or something else? Is someone has a spare for sale?Thanks.
1992 SVX whitepearl 129,000km 2005 MAZDA3 red 38,000km 2001 HYUNDAI XG V6.3000 2003 TOYOTA PREVIA |
Re: help,turn key to start,no sound
You will want to do a search on this, try seaching for "starter relay bypass"
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Could be the neutral safety switch, which is the mechanism that prevents starting the car in any drive gear. Try shifting into Neutral next time this happens and see if starts then.
It's either the ignition relay or the park-neutral safety switch. The ignition relay goes through your steering wheel and is a bugger to replace but not totally terrible. The park-neutral safety switch is located underneath your center console (like directly below the emergency brake) and probably easier to fix.. just depends on how easy it would be to move/remove the center console off. A while back, I had an ignition switch issue and with that fixed.. now, I think I too suffer from the neutral switch issue.
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE Last edited by lhopp77; 08-17-2010 at 09:42 AM. |
Ill check all to see. Thanks cozykat,could you tell me about your ignition issue? cos at first i thought it was my loosen ignition switch that present the problem,after the cover came out,there was a screw that hold the switch that was lossen,.But after tightened,the problem still exist. So,may be i hav to check the relay first. thanks. SO,if anyone know how to test a starter motor to see if its good or bad? and how to test a bad relay? sorry,i just a novice. THANKS ALL,THE BEST.
You need to fit a 30 amp Bosch relay to the starter solenoid that is on the starter motor. Any auto electrical shop will know what this is and fit it for you. This a link to the way it is fitted. http://www.subaru-svx.net/forum/show...1&postcount=23 Harvey.
I suggest you check the thread in my signature.
NM here http://www.subaru-svx.net/forum/show...ighlight=click
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
the bypass mod is a 4 terminal Bosch relay and the factory one, the 5 terminal one could even be Bosch, but not necessarily a Bosch, that is used in conjunction with the SVX factory oriented security system circuit is a 5 terminal relay, using a normally closed position of contacts during the start process. This 5 terminal relay is not energized during the start process. The factory 5 terminal is also used in conjunction with the security system to prevent starting if alarm security is violated. Keith Last edited by kwren; 08-18-2010 at 01:20 PM. |
Im still betting 5 forum Pesos it's his Neutral Safety Switch, he says he hears no clicking or anything when he turns the key. He hasn't verified he tried starting it in Neutral yet..... I believe this test is the most simple to do and easily eliminate the NSS as a cause, as you only have to move the gear selector a couple clicks down.... not exactly hard to check.
Just my 2¢ |
I wouldn't put money on the notion that there isn't a "Bosch relay" buried somewhere in the vicinity of the car that does the same thing as the 5 terminal relay does on ours. With a wiring diagram, it would be a snap to find it. Maybe someone with one from those other country's would be nice enough to attach one?? Thanks... Keith |
As far as I know, only the US cars came with a security system. The Australian car's circuit only has the, Ignition switch, and the gearbox selector switch in the starter circuit. As it is usually starter in the Park position, that is the one that gets worn the most. So in Tigers case, if it will start in N, it is the gearbox switch. If it won't start in either P or N, it is the ignition switch, or some other obscure wiring fault. It appears that the US security relay has a normally closed contact that ages to not make a good contact. So 'you all' have a third set of contacts to give trouble. Harvey.
