Old 11-29-2008, 02:45 PM
Blacky Blacky is online now
All switch lights not working
None of the tiny lights in any of my switches work. I just replaced the switches to the left and right of the steering column and still nothing. The ones in the overhead don't work either. The 7 bulbs in the dash gear selector, power light, manual light and ABS check code light also are off.
The bulbs can't all be burnt and the ones I've checked visually seem to look fine.
My ABS and airbag warning lights are both on and the AWD is not working. I can't check the ABS and transmission codes because the lights don't work. The airbag code is for the module which I replaced yesterday but I think the replacement module is also no good because of an accident.
Old 11-29-2008, 04:59 PM
Manarius's Avatar
Manarius Manarius is offline
Re: All switch lights not working
There is a fuse for those lights. I don't remember which one it is though. Have you checked that?
-Jason
-Obi Wan Kenobi
Old 11-29-2008, 05:37 PM
There's 1 fuse for all the tiny lights? That seems odd but I'll check the fuses again. I think there are deeper electrical issues with this car.
Old 11-29-2008, 07:48 PM
kwren's Avatar
kwren kwren is offline
could maybe be fuse #26... 15 amp... behind left side of dash?
Next would be why it is bad, if it is?
Old 12-01-2008, 02:29 PM
Fuses are all good. How can all the gear selector lights be burnt at once. All the overhead lights too. The car must have had a power surge or something before I owned it. Almost everything electronic is messed up and the car is totally electronic.
Old 12-01-2008, 07:27 PM
kwren's Avatar
You checked all the fuses in all the different fuse locations?
Even under the left side of the dash... Visual check or actually tested them to find out if they are really good?
If your car was messed up when you got it, that puts everything in a different prospective.
Old 12-01-2008, 07:34 PM
kwren's Avatar
No interior lights when the door, left or right, is opened?
Again... could maybe be fuse #26... 15 amp...or #25 10 amp behind left side of dash?
Carefully test all fuses in fuse box behind left side of dash.
Old 12-01-2008, 08:33 PM
The interior lighting works, dome light, map lights, visors etc. It's the backlight bulbs in the overhead switches , seven gear selector bulbs in the dash, power light, manual light, ABS(which doesn't work) light under passenger seat, on light for defogger and cruise (which doesn't work). All the warning lights except power light up when the key is turned on.
I tried swapping fuses in both fuse boxes. It's a head scratcher. I do all my own repairs but electrical is not my cup of tea nor most mechanics it would seem.
Old 12-01-2008, 10:24 PM
kwren's Avatar
out of time today will keep looking tomorrow evening...
Keith
