Mysterious 'clunk' from front end
Hello SVX lovers.
MY SVX has just started making a clunking sound from around the front left (passenger side). My car is RHD. Could this be bushings? Or could it be a bit of play in the steering rack? Rock on.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com |
Re: Mysterious 'clunk' from front end
I would suspect the ball joints, lift that wheel in the air and try to shake it up and down/side to side and see if theres any play.
Thanks man.
There does seem to be a little play.
I'll bet you've lost a sway bar bushing. Simple fix; check that first.
dcb |
+1 on that
Is the noise constant or only when going around a corner or over bumps? A little more detail on the noise can help
It clunks during cornering and going over bumps. It seems to be coming from one side in particular.
My SVX is due for a new set of bushings and rubbers. The suggestion that it may be the SWAY BAR bushing sounds valid! I will take it to a suspension place very soon. Cheers!
I am finding it quite challenging to source sway bar bushings here in Australia.
Any Aussies have this problem? Should I order from the US of A?
I struck out at a couple of local aftermarket outlets before ordering from Subaru. Seems a dealer there should be able to order them for you.
dcb |
