View Poll Results: Calipers Failed: | |||
Front Driver Side | 7 | 58.33% | |
Front Pass. Side | 5 | 41.67% | |
Rear Driver Side | 6 | 50.00% | |
Rear Pass. Side | 2 | 16.67% | |
Multiple Choice Poll. Voters: 12. You may not vote on this poll |
Thread Tools | Display Modes |
Caliper Failure(s)
Which calipers have failed on you during ownership:
1. Front Driver Side 2. Front Pass. Side 3. Rear Driver Side 4. Rear Pass. Side
1994 subaru svx le 112k |
Re: Caliper Failure(s)
nothing so far
SubaruJawn,
You had ALL of your calipers fail? .
Not necessarily a failure but I noticed that my left rear is sticking at times. Enough that the pad is down to the backing plate while the other side has about half the pad left. Good thing I've got a bucket of calipers
Fail or require replacement??? There's a difference.
None of mine have failed. However most of them have been replaced during maintenance.
You need to add the choice to select "No Failures" in your poll. Otherwise the poll assumes that at least one caliper has failed on every SVX.
