Where/who to buy head gasket set from??
Looking for a supplier, preferably US based (more trusting) I have a 1992 SVX and its been so far an extreme money pit, obviously the last owner knew this but hey.. It needs the heads doing and I need to get a gasket set - who can you guys recommend your side of the ditch Many thanks in advance, Craig.
Re: Where/who to buy head gasket set from??
Hello from Finland :-)
You will probably need a full factory gasket set, right? I've used Mastria Subaru with great success. Jim is very helpful and shipping has never been a problem. jlecesse@mastria.com As many others, I replaced the OEM head gaskets with Cometic MLS ones. You can get these from Dayle motorsport_svx@yahoo.com for example - I bought mine from Flatirons Tuning in Colorado because I ordered other stuff from them at the same time - they had a set of ARP2000 head studs custom made for me. Kind regards, Tapani PS Does anyone know what happened to Jackie W at Annapolis Subaru? She hasn't replied to my enquiries since March... Last edited by Tapani; 12-27-2014 at 11:04 PM. |
Hey Tapani,
Cheers for that, will take a look. I have seen the Comitic on ebay but unsure of the different sizing 100mm 98mm etc How will I know which one or is it on the chassis ref/numbers?? Many thanks again |
These are dimensionally equivalent to the stock gaskets:
Cometic Head Gasket for Subaru SVX EG33 98mm .066 Inch MLS-5 C4340-066 As you have noticed, you can get these to match your (over size) bore size and in a selection of thicknesses to match your preferred CR target. /T Last edited by Tapani; 12-28-2014 at 12:18 AM. |
Thanks again Tapani,
What a gent will go for a search now... |
Bought both the full head set and a new timing belt just for good measure. Cheers again Tapani. Have a great new year
While you have the engine out be sure to replace the rear main oil seal and reseal the "kidney plate".
Also, if the cam cover gaskets are not included in the set you bought make sure you get them too. Further, replace all vacuum hoses + PCV-valve while you have the intake manifold off . And inspect the flex plate for any signs of cracks. There is a thicker one available for around 30 USD. /T |
If you are changing to a mls gasket I would recommend changing to studs at the same time. Mls gaskets require different torque specs and procedures.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
All good guys, Iv ordered the water pump + pulleys too. Will have another look on ebay for the studs (bolts).
