Old 08-20-2017, 02:41 PM
willisjefferyl willisjefferyl is offline
Banned
Main (driver's side) Power window switch
Looks like only the driver's side window switch has gone bad in the master switch. I was gonna swap the entire thing. Does anyone know if these are the same in all SVXs? Same fit? I found one from a 92 but they claimed it wasn't compatible. Looks identical to me like most things among all SVXs. Thanks guys!
Old 08-22-2017, 08:54 PM
lsupcar lsupcar is offline
Re: Main (driver's side) Power window switch
I bought a new switch about 5 or 10 years ago for my "92. The new switch had auto up and down for the driver's window. My '92 did not have that. Otherwise the switch and connection was the same.
Old 08-23-2017, 07:37 PM
I bought a new switch about 3 years ago for my 97. At the time, 96+97 had different part numbers than 92-95
connector MAY be the issue.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 08-24-2017, 12:07 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
The only real difference is that the 92 models had Auto UP & DOWN, while the 93+ had only Auto DOWN. The connector itself is identical.
-Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
