How to Clean IRIS valve?
We picked up a cheap used manifold for possible use when installing the phenolic spacers (web removal, clean up and clear coating etc.). We removed the IRIS valve and found it very groady. We tried wiping it down with isopropyl alcohol but some of the mung is baked on. Would spray carb or brake cleaner be ok and not damage the diaphragm?
As expected the IRIS oring was pretty crispy.
"Peace is the flower of justice." |
Re: How to Clean IRIS valve?
Sorry, I don't have an answer to your question! Would you happen to have pictures of the process?
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
What process? We have not done much yet except pulled the IRIS and covered the manifold open ports.
i would use carb cleaner. generally don't want to use brake cleaner on engine parts.
