ECU:How does it calculate Timing??
Hi all. Been messing around with the datalogging software in correlation with the select monitor. I took the car out last night for some extra hard runs to see exactly what is happening with the ECU... Here are some points.
1. Spontaneous acceleration and hard driving are fine... Car pulls well but seems to have a minor restriction... Just doesn't feel 100%. 2. 1/4 mile run.... half way through 3rd gear the car falls flat on its face. Monitoring the MAF signal, load, TPS, knock correction... Nothing seems out of place and all seems to be working properly. Only problem is, my advance has gone to ****. At full load it has about 6-8* advance BTDC which is absolutley killing the engine's performance not to mention spiking my EGT's up to about 1500*F. I looked at knock correction (retard) with both the evoscan software and with my select monitor and it registers 0 at all times. But monitoring the advance on both confirms that it is drastically low... 3. Car runs great through normal driving yet I am still having an idle issue. My thoughts were always that the only way to pull timing out of the base advance is to have a knock condition in which the ECU could pull up to 10 degrees from the advance.... BUT since the retard function on my SSMI and the evoscan software say 0 all the time... how could this be possible? I am at a loss of thoughts as to why my timing could be so low??? any ideas? Tom Last edited by TomsSVX; 09-11-2008 at 10:26 PM. |
Re: ECU:How does it calculate Timing??
DId you end up using race fuel as mentioned or did you stick with pump gas?
Yea.. was using 103 octane race fuel as well b/c when I got to the track... my fuel light was on... I originally wanted to get two runs on pump gas and 2 on race fuel at least.... But It was too low to both racing on what I had left of 93
Tom |
I guess this is the blowen engine running 9psi-12psi?.
What do you expect the spark advance should be at full throttle? Harvey.
yeah, more info, please!
-Bill
Tom Last edited by TomsSVX; 09-13-2008 at 06:47 PM. |
YT,
Any possible "back doors" to the timing tables? Any sensors that you're not datalogging that could be sending a signal that is causing the timing to be pulled back? I'm wondering if you aren't producing a combination of inputs that are putting the ECU into "self preservation" mode, thus pulling timing. -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 09-13-2008 at 07:12 PM. |
