Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 10-13-2006, 11:29 PM
sicksubie's Avatar
Need advice on what route to take
Alright, I have reached a point where I need to now make a decision on what route I want to go with the SVX. I don't want to spend money on stupid little things without any real direction. I am considering two options and would like feedback on both.
Option 1: Build an EG33; Bored out to 99.0mm with Wiseco custom pistons, the same shop that would do the boring would also work on the crankshaft, Gasket works custom copper head gaskets, I would stick with the stock rods, obviously all new bearings, the head would stay stock for now, but down the road valvesprings, retainers and cams (specifics unknown at this point). Then it would be a turbo set-up similar to Phil's or maybe a stage 3 ECUTune, either with a 6 spd tranny.
+'s: keep the awesome sounding EG33, the sound of a BOV, the whine of a turbo, keeps the AWD
-'s: very limited engine management systems available really puts a cap on the potential of this system ( I know LAN rocks with the stuff he has developed but we still lack big time in this area)
COST: approx$14-17k
Option 2: 302 V8; Trick Flow Twisted Heads, 10.5:1 CR, RWD, 5speed,
+'s: great sounding ford 5.0, completely original, 390rwhp
-'s: Maybe sacreligious to some people, lose the awd capabilities of the car, suspension issues due to front end weight.
COST: approx$9-12k
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-13-2006, 11:34 PM
sicksubie's Avatar
And for the nay-sayers please note. The two of us that will be doing this have put a 305 chevy in a 4 door saturn (ridiculously fast) and built a tractor last year and powered it with a 302 out of an old mustang. So the abilities are here to make the V8 fit. However we have not taken final measurements. That will be done hopefully some time this weekend. At that point we will know exactly what will fit. In the mean time post away, rant, rave, offer advice, criticism, anything you want.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-13-2006, 11:56 PM
sicksubie's Avatar
Almost forgot one other project. A log splitter powered by a 2.3L turbo out of an old Ford Thunderbird. There is also a work in process of a lawn tractor powered with the other 2.3L turbo and running on Mickey T's that we have lying around. Just trying to prove that I am crazy enought to possibly attempt this.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-14-2006, 01:02 PM
NeedForSpeed NeedForSpeed is offline
If you consider a v8, get a lighter modern engine, with four cams just like the eg33. The 302 is a dinosaur, heavy cast iron, two-valve, boring engine, nearly 50 years old in design. Okay for a lawn-mower, but not in an svx. All the time and effort, and you are left with a 'drag' car.
If you have to use a v8, use a modern sophisticated engine like the Infiniti, Lexus, Northstar, or whatever fits. We had a thread about that somewhere.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 10-14-2006, 07:14 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
COST: approx$14-17k
COST: approx$9-12k
Well, if your going to do a V-8 swop, use a Chevy crate motor. My uncle just picked up one to drop in a '69 Camaro body. His is a small block 454ci. Dyno tested at 600hp and 573LB/FT. running straight carberation. A nice LS7 will add big power without as much weight as the 302 ford. If you prefer ford get the newer 4.6L. You need to look at going alumanium block or your going to end up adding way to much weight out in front of the wheels. Personally I'd stick with the EG33, or at worst a 2.5L STi engine. Also for a tranny,(and you didnt hear this from me) the new WRX 5-speed has 3.70 gears and is much strong than the older 5-speeds.
Old 10-14-2006, 10:30 PM
I can fully appreciate the want to put a v8 in the car but it really isn't realistic except for a drag car. There would be too much a weight bias and you would be lighting up the rear tires even with MT's on the car. The nose would be too heavy. If you really want a project... twin EG33 svx. It gonna be auto but it will be fun as hell!!!
Old 10-15-2006, 12:21 AM
92svx95 92svx95 is offline
hmmmm i always thought a 454 ci motor was a big block unless bored and stroked. coming straight from a crait i would assume it was a big block... smallest small block i know of is a 396 rat.
Old 10-15-2006, 12:22 AM
#biggest small block chevy i know of is a 396
Old 10-15-2006, 12:26 AM
there was a run of 400 small blocks. There was issues with water and oil jackets though, cannot remember which exactly
the 454 is a big block, so you are correct
Old 10-16-2006, 05:16 AM
mikecg's Avatar
The LS7 in the new Z06 Vette is a 427 small block. It isnt the same small block as the previous chevys, but they still label it as a small block. The 454 my uncle got is based on that block.
Old 10-16-2006, 07:04 AM
sicksubie's Avatar
Thats what my friend suggested. He wants to take the 427 and make it a mid engine car. If he owned the car ( cuz he has the money and def the time) he would probably do it.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
