code 32....AGAIN!!!
ok here's what's up. my car started throwing a code 32 after i adjusted my brake band and put in my 20 ohm resistor. now whenever i put the car under load in 4th gear the light comes on and doesn't go off unless i go over like half throttle or so. then it stays off untill i put it under load at low rpms or cruise at low rpms for more than a minute or so. i had the dalership replace both o2 sensors in nov. and the rh one was bad right from the start with the exact same conditions as now. they replaced it again and it's been fine till now. what the hell?? i have to spend 200 dollars for o2 sensors every 6 months on this car??? this sucks. anyone with some ideas???? by the way, my cat was clogged for a while and so was my pcv so it was drinking plenty of oil. i figure that didn't help but what do you guys think?? Jason
Timing belt jumped a tooth?
only one way to find out easily. i'll switch the o2 sensors and see if the code changes, if not, i'm screwed. |
Mine was kicking code 37 and 32 when my timing belt was off by a tooth or two. Have you noticed any power loss? You will not hear a difference or for that matter feel a difference if you drive normal. I drove for almost 6 months with a timing belt out of timing before I figured it out. Gas milage is big sign. What are you getting for mpg?
Steve
92 SVX AWD 130,000 w/ rebuilt SVX 4.11 97 Audi A4 1.8T (Daily Driver) 03 Ford Expedition(hers) SVXepidia SVX information warehouse Are you in? My Old Locker A 4.11 Founding Father "Tranny #6" I really need a manual Reading IX [SIGPIC][/SIGPIC] Ya I was there
the only code i'm throwing is 32. the gas milage is about average and it's gone 6 months now without throwing any codes. when i bought the car it was showing 32 and 37 so i had the dealer put in new o2 sensors and the passenger side one they put in was bad out of the box. they put on another one and it's been fine till i did my brake band and now it's code 32 again. the light didn't come on yesterday at all and only once the day before. does the computer just stop setting off the light after so long? something i've noticed both times now is when it first registers the code the light comes on a lot and as the days go on it comes on less and less. it was running super strong but i think the computer has learned now(had the batt disconnected for brake band) because it's running pretty crappy now compared to usual. from what i can figure this car eats o2 sensors left and right from what i read. i'll switch them when i get a chance and see if it switches to a code 37.i've never play with many ohc engines and i'm very intimidated about removing the front cover and doing the cam timing if that is the prob. so i'm gonna investigate all i can before i go there. |
It is not that hard to replace the timing belt or reset the timing. You can download the manual I have attached to see if you wand to give it a shot. I was advised by the subie dealer to use the big paper clips, black ones that the metal handels flip over, those ones. Use them to hold the timing belt inplace on the cam sprockets. the hardest part is compressing the tensioner. A 5" jaw vise workd best.
I think that the timing belt might be an issue. Mine did not always turn on the CE light when I had the problem. Car warmed up on came light, little bit later out it went. some times it did not come on at all. Good Luck Steve
