Rubber trim on top of rear wheel well?
How do I remove that black rubber trim that is along the outer edge of the rear wheel well? The ones that sit up against the body.
On my car they are pulling away in places towards the rear, just enough to not look right. I would like to replace them sometime in the future. Or even better, figure out a way to make them sit flush with the edge. From what I can tell it looks like it slips under the side skirt and rear bumper cover, but I'm not sure where they actually attach. Any advice is appreciated. Thanks!
Re: Rubber trim on top of rear wheel well?
This was the first thing I did to my SVX. I believe you can pulled them off. Pull them in the same direction of wheel well curve slowly. Do this only if it comes off easily, if not wait for some more advise.
Anybody got a pic of what your talking about? I'm picturing my SVX and don't think I even have it, nor have I ever..
I'll try to post a picture of it when I get home.
Did you replace yours, or did you just leave it off?
might try taking a couple of bolts out first?
Keith |
Here is a close-up shot of my front fender well. See the thin strip of black rubber along the inner edge of the fender? It runs the entire edge of the metal fender only (not the bumper or the cladding) The rear fender well looks the same. Here is the diagram Here are the part numbers from subaruparts.com. Located in the Body Parts section under "mud guard". 59121PA001...Protector, front arch, right...42.90 59121PA011...Protector, front arch, left...42.90 59121PA020...Protector, rear arch, right...44.32 59121PA030...Protector, rear arch, left...44.32 ,
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-09-2008 at 03:20 PM. |
One or two of mine are starting to peel away as well. I would be interested in any info on fixes.
Why would you remove it? I don't think I have the thing in svxcess' picture. -- Rear:
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 12-09-2008 at 03:11 PM. |
Nikfu- Yours looks much different as mine is identical to svxcess'
That's because mine are JDM tyte, yo.
I don't even know if I have any... Was this standard on ALL svx's?
I would think so as mine is a 92 and has it, svxcess' is a 96 and has it.
good point
Mine did not look like Nikfu. Mine was like SVXcess. There could have been two screws holding it as the parts list shows. It was coming off, so I just pulled on it slowly until it came out. No I did not replace them.
