Oil spewing out of the breathers.
I've got oil spewing out of my breathers. Any ideas?
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
Chuck,
Pics of your set up? Normal set up is that the PCV system takes care of this... -Bill
Check the PCV valve and see if works. That may be your problem. That should not be happening.
Oil out the breathers.
Chuck sounds like you are getting boost into the crankcase. How have you got the crankcase ventilation set up?
Engine Dead
I think this is the case. It just started happening, so I don't think it is a problem with my crankcase ventilation, which is ventilated directly to the atmosphere, along with my cam vents. I am thinking either rings as trevor said, or perhaps a hole in the piston. I have had no detonation events that should have caused this. It is an older motor though 135k. It may be time to bite the bullet and just pull the engine and rebuild it. I am also getting a fuel smell from the vent. I seem to miss once in a while as well. I think it is pretty apparent from the folks who are using FI that more is required to achieve this. Intercooling and lower compression for starters.
Chuck,
ouch Have you pulled the plugs to see if they tell you anything? Might also be a good idea to check the timing belt - I'm wondering if the intake and exhaust cams are "off" thus throwing off the combustion event (i.e., raw gas being shot out the exhaust, pressurized crankcase gases being pumped out the vents, ...) -Bill
