rear camber bolt size?
are the front camber bolts the same size as the rear? i don't think so, but i'm hoping they are cause i can get an extra front set easy. if not, what size do we need?
yes they are, i looked into this as i need to adjust the rear camber for my new rims
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
excellent thank you! will get my hands on these this week end and report back.
update, the OEM front camber bolts will not fit the rears, they are too large. i've grooved/notched out the oem rear bolts and will try to get a little camber adjustment that way. will tell you if they work later when i get a chance to put them on and measure them up.
