MAF wire mod
Guys if you find you self stuck in a desert with broken wires on the MAF plug here is the perfect fix. All you need if a couple of safety pins and some scotch tape and the problem is solved.
Tony
Good number 8 wire stuff. I trust no one was left with their nickers in a twist.
This should be in the technical section as it is a fix for any plug/socket connector problem. Pins, nails, hairclips, the list goes on and having the most likely donor on hand, will ice the cake.
I'll move it. I will have to remember this for when I go out into the desert.
I've used a dinner knife to replace a fuse that kept blowing... the ignition fuse.
took me a long while to find a previous owners messed up modification that left a loose wire that would swing around in the enginebay shorting on occasion. BTW dinnerknife fuses are good for some fairly epic lightshows at times so I only reccomend it if the alternative is worse. |
Not a good one to be recorded in the how too data.
Used cirigrette paper as a fuse on a Black & White TV years ago. It fixed it permently, smoked up the house pretty bad.
