Old 11-30-2010, 02:55 PM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
Noisy lifters and the magic Honda oil filter.
I have a 99' Acura RL with 145,000 that's doing exactly this:
http://www.justanswer.com/questions/...they-put-mobil
I did not put Mobile one in it, but I did start using Fram oil filters around 9K miles ago when the problem started. At first it was just a mild tick, big deal Honda's do that. When I got the thing you could not tell it was running. Now it ticks just like noisy lifters but real loud, almost a knocking. It's pretty bad. Worse than any Honda's usual ticking that I've heard before. It does not get better when the valve train warms up either.
So, I'm wondering, is there such a thing as an oil filter check valve that prevents oil from going back into the block? Would that cause engine noise?
Old 11-30-2010, 03:36 PM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
Re: Noisy lifters and the magic Honda oil filter.
I have heard of the check valves before, not sure if the honda one has one or not. Though i would never use a honda filter any more. I think every single one is made by Fram these days.
When was the last time your valve lash was adjusted?
also, ditch the fram filter, go with a purolator.
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 11-30-2010, 06:26 PM
Originally Posted by StatGSR View Post
Ditch the Fram filter, go with a Purolator.
+1
Fram filters are about the worst, most problematic filters I have ever used. Read this review of a Fram filter from a 1991 Honda Accord.
http://www.dslreports.com/forum/r218...-FILTER-REVIEW
Old 12-01-2010, 05:36 AM
greggbzz's Avatar
Awitha Cheese-ahhh!
Yea... come to think of it I've never gotten a car back from a mechanic with a Fram filter on it.
I might try sea-foaming the engine, or taking it to a good Honda mechanic.
I've tried 10w30 and 5w30 (which is the recommended viscosity) no change really.
Such a nice car.. hopefully the engine does not explode.
P.S. From what I understand this car has hydraulic lash adjuster, but they can wear out. Maybe I should take a head cover off.
Old 12-01-2010, 07:47 AM
^ could be, i don't know much of anything about the honda V6s, pretty much just know lots of useless crap about the I4s...
