Will this used harness work? Need confirmation
The first picture is of my current harness removed from my vehicle (under intake manifold) It is only missing one pin in the corner of the connector.
I picked up a used harness from another member on the site and now not sure if it will work because it's missing a few more pins on pictures 2 and 3. Question 1) Will the used harness with missing pins work? Question 2) THe used harness has a gouge in the wire in picture 4...what's the best way to fix this? Just add a little solder? Please advise Thank you. |
Re: Will this used harness work? Need confirmation
I could probably scare up the electrical diagrams of the harnesses and let you decide. You probably have a 92 version and then a later version from an OBDII setup. Later models had a couple changes with the additional 02 sensor coming to mind as an example.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
