AT ...or not?
Should I plan to rebuild AT while performing head gasket service on engine (to be removed)....or just wait til tranny problems show up? I've heard in the past that our Nissan AT's like to need a rebuild @ about 120,000 miles...? My SVX has 111,000 miles! The only problem I've had with my AT is a slow (sloppy!) shift from 2nd to 3rd...BEFORE I installed a Smallcar.com Shift Kit!
THANKS for any help!
I prefer the Idea of a manual swap over the cost of rebuilding the auto.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
AT rebuild is expensive and doesn't require the removal of the engine. You're not going to save anything by doing it now. Might as well wait until it does start giving problems.
If it aint broke don't fix it.
MANUAL vs AUTO
How much is a manual swap? Is it a clean result....Or does it entail "custom" alterations that appear homespun? How much more HP ....or zip?
Thanks! .....for your opinions! P.S. Is there anything to doing an AT rebuild that could beef up.... or even improve performance of the AT?
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 08-12-2005 at 02:29 AM. |
I agree that you might as well leave the transmission alone if it's behaving. As to switching to a manual, it's one of those things on which you can spend very little or quite alot, and the result, both aesthetic and mechanical, would depend upon the skill of the person(s) doing the work.
As to "how much more HP?" Zero. dcb |
If it ain't broke........don't fix it. My tranny has 165,000 and is doing fine. There are others with high mileage also. Unless you have money burning a hole in your pocket or you're planning a very long road trip I wouldn't spend any money on it right now. I personally won't touch my tranny until I lose a gear....or two
Dave |
you won't gain any hp from converting it, however most people love the feel of the svx as a manual. as far as "beefing" up the auto., i went with a rebuild kit from level 10 and it feels great. costwise it would be about the same to rebuild the auto as opposed to a manual swap so it's mostly up to the owner and whether or not you can find someone to do it (i couldn't ) |
REBUILD AT....OR SWAP to 5-Speed?
How much would this cost?
