Top speed, air sensing, and fuel
So I have this purely hypothetical situation, where there is one of those air mass resistors installed onto an SVX, possibly richening the fuel by great amounts.
Let's say everything else is ruled out over the course of a year. What are the chances this cheap ebay mod, which noone should ever install, is limiting the top speed of this SVX to 125 mph, even causing it to drop the tach to around 4k at that speed? Does this sound like the fuel pump or something related is put on hyper overtime and is just too tired to push on?
Hypothetically speaking, if one were to hypothetically bypass the hypothetical resistor and do a hypothetical speed run, one would know if the hypothetical resistor was the cause of the hypothetical speed limitation.
This is all pure theory, I know nobody would ever actually try this. |
No, I would say the tranny is just shifting from 3rd into 4th gear.
edit: Also let's say this vehicle was tested at 140 before the install of this cheap ebay horsepowermatic-magico device. And what if someone had it on video?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 10-07-2004 at 10:24 PM. |
My car is Not speed limited to 125 so the Item sucks( or blows) and sokmething needs further improvement.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker 2002 Mitsubishi Lancer OZ Rally [Nori] 1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling 1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone) 1992 LSL Ebony Mica (Sold to svxcuseme) |
Hypothetically noted.
edit: You used AS3 to make that avatar, did you not?
I was hypothetically doing high speed runs a while back and noticed a few things:
1. Over the counter octane booster works wonders when used with quality gas 2. TIRE PRESSURE is of paramount importance. You are hypothetically going to be limited to about 125-130mph if your tire pressures are set "correctly" to 32/28 front and rear due to the drag of the rubber having to flex so much. You must therefor theoretically raise your tire pressure a bit to hypothetically reach higher speeds. Just be warned: a. NEVER, and I mean NEVER inflate your tires above what is printed on the side of the tire b. NEVER, and I mean NEVER run max tire pressure when doing high speed runs due to the air in the tires getting hot and expanding So hypothetically run your Z, Y, or W rated tires around 44 psi (if their MAX is 51) and be damn careful. 3. The sunroof makes a pretty good active spoiler 4. There is no forgiveness at 120+mph, and your car WILL hypothetically start to lift at 150 or so without an active spoiler. All that being said, have fun and be safe. And try to save your passes for Bonneville. |
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 10-11-2004 at 09:07 PM. |
I'ma head to the gas station at the other end of town.
Tell ya if it runs better when I get back with some donuts and a Sobe Love BusBrew. Mmmm... Always remember to check if your battery is plugged in.
Ohyeah, now we're cookin' wit gas.
The transmission is shifting about 500revs earlier, a lot quicker, and more smoothly. This probably makes it seem as if it's faster. I didn't try to tach out, or even go into power mode. I'm sure it won't stick anymore.
