#106
#107
Actually the $600 price tag vs $18,000 for a 3.6 turbo was the breaking factor in going to the suby side of H6 wonder.
Your camshafts are on a laundry list of internals to get from you. I'll combine those with some work on the Rottler and the heads should be good to go. Quote:
#108
If you have a vertical machining center do a step deck; I'm very happy with mine.
How much did you knock off the outer ridge on your particular case halves? ~.0015 is about the norm for most engines getting that treatment. I'm not looking for much power here. 450-500RWHP in a 2000lb car will be more than adequate! But anything to help seal those center cylinders is an added bonus. |
#110
yep, 15 tens
#111
Higher RPM loaded and running. I always liked the sound of our engine N/A when it is running in its power band.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#112
-Bill
#113
What are you doing Sunday? I'm thinking of going to sunday runday at Bradenton.
#114
I have a question for you that is slightly off topic. You mentioned having some special plans for this motor. I was thinking intercooled turbo. Are you planning on keeping the iris system for that? I was thinking of running the iris system like you are during break in, but then jamming open the iris valve to see if there are any noticable changes in idle or power. It might be interesting to see what the difference would be on a dyno. I doubt it is going to be significant for a FI application. I noticed you didn't have one installed for your supercharger kit.
#115
Have you considered dyno tuning your mods "as is" when you are done breaking in the motor? It would be interesting to see. It would also be interesting to see what power improvements you see with your valve train/cam improvements and the stock bottom end.
#116
ok, here's your bow
#117
I'll be doing that with the engine I build for my pearlie. It's getting the 9.3 compression ratio pistons and 256 duration cams for both intake and exhaust.
#118
[QUOTE=longassname;520238]ok, here's your bow
/QUOTE] Michael, Nice! Looks like you've got the same fuel pressure gauge set up that I do What's with what looks like 14 ga wires running around between the Alt and the PS pump? -Bill
#119
My alternator wiring went bad some time ago and I replaced it.
#120
Vroom Vroom time. Congrats. Have you fired it?
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
