Torn driver's seat..
Is it possible to get my fabric (and vinyl?) seats repaired? I just need a new section of vinyl.. on the entry side of the driver's seat .. where I rub on the outer side (upright) of the back section (rub when getting in/out). The passenger side looks fine.
OR.. Can we get stock covers (skins) to replace the entire seat upholstery (over the stock foam?)? My car is a definite "driver" .. so, I dont need perfect interior.. I would just like to replace that one vinyl (foam popping out in 2 small holes.. about 1" diameter) section.. ? Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 03-09-2011 at 04:58 PM. |
Re: Torn driver's seat..
you can look into some sort of vinyl "patch kit" or something to that effect. otherwise i would say you can look for a seat cover, or maybe find a reasonable upholstery shop, then again i am the kinda guy who would take out both front seats, and move the passenger one over to the drivers side, just so i could still drive the car while the driver seat was getting upholstered.
2003 Baja Sport 1994 SVX LS 1992 SVX LSi parted out |
Keep an eye out for part outs near you, it would be easiest if you could just replace the entire seat.
