QUICK Dead Battery.. ???
Heh.. When I leave my key in ON position.. for less than 5 minutes.. .
MY BATTERY GOES DEAD THAT FAST.. !!! Is that normal, since I run with my lights on all the time? Thanks, Jim P.S. Happened when cop stopped me once.. Plus many times when working on car, and needing in Neutral (like to move car, or working on shift linkage).. like YESTERDAY.. ThOT I had something in tire (Low?).. so put in Neutral.. pushed back.. left in ON for 3-5 minutes... DEAD!!!
Re: QUICK Dead Battery.. ???
no that isn't normal. you should be able to leave the car on even with the headlights for at least 5 minutes.
what condition is your battery and charging system? |
No, not normal. I run with my lights all the time, too. You've got a weak battery, failing alternator, or both. Or maybe some wonky circuit that's drawing abnormally.
dcb |
WELL.. . the alternator was replaced (about 4 mos ago) .. after battery went dead resulting from 5-7 min stop, when COP stopped me, left key ON! Battery was checked (and found GrEaT!) about two weeks ago.. I took it out .. and to Pep Boys! [After similar incident.. battery GOT dead from similar situation.]
I know where the starter circuit is! .. .Where is the WoNkY CiRcUiT? Thanks, Jim P.S. Battery is $180 Interstate!
Are you sure the battery is dead or is it that the starter won't turn the engine to try to start it?
Keith |
When this happens.. Then, the dash lights go out when trying to start! But, you may be at least partially right.. . The solenoid/starter may have been shorting..or sucking way too much juice when malfunctioning.. ??
After replacing starter two nights ago.. starts great.. A week or so ago.. I took battery out.. to Pep Boys (where I bot it) .. they said it was GOOD.. ?? Today, I went to Autozone.. They used a meter on the in-car battery.. They said it is DeAd! .. ??? [CHarging OK] Of course, I'm not anxious to turn key ON for 5 minutes (without starting).. . to ChEcK!? Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 10-27-2011 at 11:34 AM. |
Battery chargers are actually very reasonable to purchase Jim. JK!! Being drawn down to DEAD isn't good for the battery as I recall, possibly causing complete failure. Battery going dead in such a short period of time says almost direct short to ground. Should be relatively easy to find with an ohm-meter. Disconnect battery and read across the battery cables, pulling fuses to spot the culprit.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket Last edited by RojoRocket; 10-27-2011 at 01:03 PM. |
