how wide is too wide?
I was looking into doing a widebody mod to the car but the car is already fairly wide. My question is how much wider should the kit be?
Re: how wide is too wide?
Gamesy, I can understand a widebody on the front end of the car, but they will look ugly on the back end. Unless you modify the METAL, I do not recommend you mod the rear fenders.
Plus you have a rare blue SVX, I wouldn't touch it if I had it in that color.
As for the color i'm gonna be doing a repaint at somepoint down the line and will try to color match as best to laguna as i can, if not i think KONA blue would be a good choice for the future. The only plans i have for bodywork is restyling the front bumper and maybe attempt the rear to make it look like that newer rear end everyone's been talking about. Other than that i'm still on the fense of whether to tune the engine or leave stock and just do a good sounding audio. Either way this summer i'll be making new fiberglass sub boxes for the trunk.
anything wider than stock is too wide.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
The steel widebody on my impreza cost around 13 grand to have done at a shop
Something like 200hours labour Unless you're a very experienced bodyman, don't try it yourself, and even if you are, get a crap car to practice on before you ruin yours. http://forums.nasioc.com/forums/show...1655704&page=4 Starts at the bottom of the page, if you want something for reference. |
Dmitry Nunquam Non Paratus |
ur only thinking this because i told you im doing it :P haha
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
http://www.youtube.com/watch?v=wTnH3vKhyps and this subaru concept http://www.egmcartech.com/wp-content...erings_003.jpg
Wow, I just watched that youtube and I highly respect the work he did on that BMW (even though the outcome is a little ugly).
But remember, this car is for show only, any small hit on the fiberglass and it will crack where metal meets FG. Always remember, metal on metal, plastic on plastic and FG on FG. THERE IS NO OTHER WAY.
I absolutely agree
It doesn't even need to be a hit, temperature changes are more than enough since they expand and contract at different rates. I don't care how good glues and resins get, it will always crack eventually.
ya thats what kept my friend from doing a FG cowl induction on his 87 Montecarlo.
on the topic of plastic on plastic and FG on FG..... when people get skirts or lips molded to their bumper, what do they use? since the bumper is plastic and the skirt is FG and yes i wasnt planning on doing FG on metal, if anything i'd make a fg replica of the fender and modify that.
