4eat question...Need help!!!
Ok here is the deal. I have a 1997 SVX that I have pulled the transmission from and done a 5 speed swap into. Left over is the 4EAT with a bad ring and pinion gear set in the transfer case... Rest of the internals are pretty much brand new when I pulled apart the transmission and inspected it. Car shifted perfect, drove fine and gear oil is immaculately clean before the pinion gear blew. Now I also have a 1990 subaru legacy with the 4eat which was towed and burned up in the process by the dumb a$$ who I got it from. Internals are fried when I pulled tranny apart. These transmission look identical from what I can tell except for the gear ratio obviously since the 90 legacy is a 3.90 and the svx is not. (sorry can't remember final drive to the svx but on with the point) The question being can I rip all the good internals from the svx and put them in the 1990 with out running into any problems. I plan on using every thing in the extension housing in from the legacy and all the internals from the svx. Is this possible. Can I do this with out any problems? the plan is to have a good legacy. Please help because I could really use a cheap fix right now. Much help was received on my 5 speed swap from every one on her so I'm hoping this is the best place to ask since every one has been so great. Thank you and any information will help. If any more info is needed let me know. I am more than willing to take pics etc. Private messages are welcome. Thanks again guys!!!
Brandon770 |
Re: 4eat question...Need help!!!
Rather than swap the internals, swap the good legacy front diff onto the good SVX trans. Search for a write up from TomsSVX on the process.
+1 The SVX transmission is slightly different but actually superior to the other transmissions. It fails because its made for long slow shifts since it was made to be a cruising car.
Thanks guys. I ended up having to rebuild the transmission for there was a couple things that needed repair in the extension housing on the svx transmission. I just pulled every things apart and cleaned it all up really good and used all the best looking parts out of the two. All I have left to do is bolt the transfer case together back on, the oil lines, the oil pan and then put it back into the legacy to give her a test drive. Looks like I may end up with quite a good transmission in the long run since I used the svx casing and internals. Your help is much appreciated. Thank you. I'll make sure to give ya guys an update if I get her in soon. Thanks again.
Thank you. Where is the C solenoid/transfer valve? |
