I need help removing my front axles.
I'm finally tearing away at my SVX so I can shove that 5mt in there. Just removing the exhaust has taken nearly all day, but I attribute that to the semi-permanent condition it was left in by the muffler guys. It's down and broke in half but I still can't remove anything from the main cat back.
Anyhoo, I'm following Tom's write up and am on step 9. I'm realizing I don't know what a roll pin or any of that other stuff is so I need a break down of how to do this part, with pics if possible. In the meantime I'm going to see if I can scrounge up that Chiltons manual, wherever it's been since I last used it, which was probably 7 years ago.
The roll pin is on the inner joint of the boot. If you look about 3/4" away from the trans and spin the axle, you'll see a roll pin going through the axle and holding it to the stub coming out of the transmission.
Use a 3/16" punch to knock that pin out. Then you can slide the axle off of the stub. You'll need to move the outer wheel hub to give enough room for it to slide completely away. You can either disconnect the ball joint or the bolts holding it to the strut. If you undo the strut bolts, mark the position of the top bolt to keep your camber settings. It will make reassembly a little easier if you completely remove the axles, but it can be done with them in place.
Removing this pin is proving to be quite a challenge.
-- and 20 minutes later it comes loose after a sound thrashing. My elbow is quite sore. -- and the other takes less than 10.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 05-10-2008 at 10:46 PM. |
You'll find that they go in a lot easier than they came out though.
I had a bit of a time doing mine, but primarily because that was the first time I did any, on anything. I've always had a sore spot for anything with a front drive train, but I learned from doing the SVX and could probably do both sides in under an hour now.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
If you drain the difff first you could just use a pry bar to pop the stubs out without removing the out pins.
There are 2 options.....
for putting the drift pin back in there are 2 different ways...
the right way and the wrong way. each choice is 180 degrees different from the other choice. If it doesn't line up perfect, don't try to hammer it in anyway. Turn the shaft 189 degrees and tap it right in. Might test it with the drift pin punch to make sure it is correct. After making sure it is correct, I would start the pin in the axle on one side and push the drift pin through the hoke and part way into the axle, holding it in place to line up the hole and gently tap the drift pin in! Hope this make sense, If not, ask and someone will explain it. Keith |
Wtf is a stub?
I need to be schooled on how to disconnect the ball joint. I took 4 bolts out of this thing and there is no change.
