Slider Pulley?
![]() Thank for the help.
_______________ 92svxman & Freida the co-pilot. First 92 Claret(flat color,IMHO) Two 92 Teal(much nicer color) 5 Speed pending, from 93 Legacy Turbo 4.11 Tranny/rear diff. May go for 3.90 Claret 145K Underdrive Pulley from Newbies2005 New timing belt new radiator new water pump new timing belt cover New headlights and harness Replaced exhaust (with stock) ![]() Life on the road who could ask for more |
If you're referring to (what I call) idler pulleys for belt tensioning, I doubt Subaru carries replacement bearings for these; they'd rather you buy the whole assembly. Pretty sure I've read here of someone disassembling and repacking (or replacing?) these, though. You might want to do a search. Good luck.
dcb |
My dad just replaced the bearing in mine. He did it while I was waiting for the replacement pulley from Subaru. I'm not sure where he got the bearing from.
Pulley Assembly
![]() Drive fast, be safe and be happy.
Do you have a part number off the bearing you used, and where did you get it.
I've been tring to track this down for some time now.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles ![]() My WRX's Cardomain Page |
Subaru will only sell you the entire pulley p/n: 34413PA000 for $38.06 on subaruparts.
Reference Link According to the PM I received: Quote:
I think I can get those at work. I'll have to check.
Info I found on this bearing. Its a standed size 6202 LU Bore 15mm OD 35mm W 11mm 15,000 RPM max Contact Sealed Type
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles ![]() My WRX's Cardomain Page Last edited by AFBeefcake; 01-20-2005 at 02:13 PM. |
![]() Quote:
![]() Quote:
O well I'll have to take the pully off when I rebuld my power steering pump.
I thought you were referring to the tensioner pulley bearing?
yes, tensioner pulley bearing. I want to replace that at the same time as rebulting my power steering pump.
