Old 01-15-2009, 11:50 AM
azsvx azsvx is offline
new ac compressor
I installed a new ac compressor, i haven't charged the system yet. Should I hear it engage when i turn on the ac or does the clutch only engage under pressure? I only turned it on for a few seconds as I wasn't sure if this would cause damage to it. any insight?
Old 01-15-2009, 01:12 PM
Re: new ac compressor
The clutch should only engage when there is proper pressure in the system. It would by who of you to get it charged sooner than later and filled with the appropriate oil to the appropriate level
Old 01-15-2009, 02:08 PM
kwren's Avatar
kwren kwren is offline
The system should be evacuated rather than just putting in refrigerant... If that was not already in the plan.
Depending of the circumstances of the failure, possible replacing the dryer-filter-strainer, what ever your term for it is.
Keith
Old 01-15-2009, 02:56 PM
Thanks guys! I thought so, just checking. Yes I plan on evacing the system in the next day or two & I addded ol before i installed it. I re did my enitre vacuum lines since I was throwing a code 34. figured replace the compressor to since mine was starting to get noisy and it was easy to get off with the manifold off. .
