Old 12-16-2008, 09:46 PM
95greensvx's Avatar
95greensvx 95greensvx is offline
Question on a 5 speed part??
I don't know what this part is called:
[IMG][/IMG]
a shifter pivot bushing perhaps? The bottom part of what is circled is missing from my car, I was driving down the road and all of a sudden my shifter became incredibly loose and this ended up being the culprit.
Any help as to what it is called so I can order one would be greatly appreciated. Thanks in advance.
06 Ford F150 Crew 4x4 142K+ miles
05 Volvo XC90 163K+ miles
02 Toyota Camry 170k+ miles
Old 12-17-2008, 10:59 AM
95greensvx's Avatar
Re: Question on a 5 speed part??
I just had a message sent to me saying that they can't see the picture but it's showing up fine for me when I go to view the thread. Well what I'm missing is the part at the base that the ball at the end of the shifter assembly lever connects into to. I am assuming it's some sort of pivot bushing for the shifter as it keeps tight shifting when you shift between gears and now my shifter is just loose. I will get a picture of my car's shifter this weekend.
Old 12-17-2008, 12:29 PM
what year/model did your donor shifter come from?? A picture on the linkage would be good too. I can help you find the right part(s) to replace it
Old 12-17-2008, 01:37 PM
95greensvx's Avatar
The transmission is from a 2004 WRX. I purchased the car with the swap already performed so I am assuming that the shifter also came from a 2004 WRX. I'll obtain some pictures this weekend. Thanks.
Old 12-17-2008, 02:27 PM
Possible answer: Part 35035, "stay" bushing.
My shifter developed a similar problem over the weekend.
Old 12-17-2008, 04:42 PM
If the bushing is missing or damaged that is one thing. It is likely that the snap-ring has come off on the underside.
Old 12-17-2008, 06:19 PM
95greensvx's Avatar
Where would be the best place to order this from?
