Old 11-05-2006, 02:32 PM
zamorush's Avatar
zamorush zamorush is offline
Send a message via AIM to zamorush Send a message via Yahoo to zamorush
Subaru Outback - gas milage problem
I have been driving my Dad's outback for the past two years. The SVX is at home, not exaclty a "carry it all" vehicle.
Recently, i have noticed that the gas milage on the outback wend down dramatically. I would usually get about 23 City/26 Highway, now, it is 19 City/22 Highway. Also, some other sumptoms that i have noticed is rolling resistance when in neutral. I used to throw the car in neutral when going down Great Vine (LA area), and it would pick up speed from 65 - 85. Now it does the opposite, and slows down from 80 to 65.
There are several things that i have tried in order to fix this problem. First, i though that it might be my catalytic converter. However, after checking the back pressure, the theory failed. I changed oil in the tranny and engine. My dad rebuilt the whole tranny. Changed fuil, oil and air filters. Polished discs, and checked the front and rear differentials. Everything seems fine.
Things i have't done are, checked the TCU and ECU. Technically i can replace them, but it is too much money.
Can anyone help me with this problem? What could have changed to bring my gas milage down and bring some kind of weird rolling resistance?
thanks
nik
Nikita Petrov (Nik)
Red 94 LSi
2013 Honda PCX 150
2011 Subaru Impreza
2009 Subaru Outback
Alternative Ways of getting around
2011 Felt Edict 9 SE
2009 Felt FX 35
2006 Cannondale CAAD9
Old 11-05-2006, 02:42 PM
Manarius's Avatar
Manarius Manarius is offline
Sticking Caliper or burnt out MC?
-Jason
-Obi Wan Kenobi
Old 11-05-2006, 07:02 PM
zamorush's Avatar
Manarius, I am not sure what is "burn out MC". About the caliper, my dad checked all of them, non rubs, sticks or anything like that.
nik
Nikita Petrov (Nik)
Red 94 LSi
2013 Honda PCX 150
2011 Subaru Impreza
2009 Subaru Outback
2009 Felt FX 35
Old 11-05-2006, 09:02 PM
Manarius's Avatar
nik
Master Cylinder. 2 years ago my brother's car had dragging brakes caused by a leaking master cylinder (more rather it was leaking on the inside).
Here's an idea: Put the car on a slight hill and put it in neutral. If it holds position, it's most likely something in the brake system. Could be a bearing or an axle.
Here's another idea: Drive the car for a while and try not to use any brake to slow it down (like speed up on a straight and roll to a stop somewhere). Check all the rims to see if one is noticeably warmer than the rest. This could be indicative of either a worn out MC or worn bearing/axle. I'd do the hill test to strike out the MC first though.
-Jason
-Obi Wan Kenobi
Old 11-05-2006, 10:23 PM
subi-crosser's Avatar
Now with more color
Both of my 97 outbacks mileage went down to 18 / 22 range when the last round of gas price GOUGING took effect. ( they were doing about 29 mpg, highway)
The cars are identical but the colors.
Both cars act exactly the same as before and both took the 'mileage' dive at the same time.
Did all the usual stuff and came to the conclusion that they are both healthy and I was trying to compensate for poor quality, overpriced fuel.
Jerry
Old 11-05-2006, 11:27 PM
zamorush's Avatar
So why did the bad gas did not affect SVXes? My svx used to get 24 - 25, and it is still the same.
Nikita Petrov (Nik)
Red 94 LSi
2013 Honda PCX 150
2011 Subaru Impreza
2009 Subaru Outback
2009 Felt FX 35
Old 11-06-2006, 11:16 PM
Now with more color
We have different politicians DICTATING what gas we BUY. Your gas ALWAYS sucks!
Ours just started sucking recently...
When a guy from Cal moved to our area,( in 1980) and brought a Chevy he bought there in the late 70's, It had 'stuff' that I had never seen holding back the performance of a car before..
Since then, I have watched what the 'greenies' have done to the automotive world in Cal,, including "Static Pollution credits", where a company can continue pouring out pollutants, IF they crush non- cat cars! ie 67 Camaros, etc.
You can tell me 'it ain't so', but Hot Rod mag proved otherwise a long time ago!
Jerry
Old 11-07-2006, 12:44 AM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
Interesting guys.. My 2.2 soob sporting cali heads took a sudden dive as well. I figured it just meant I had some fixin' coming up soon, but now I wonder
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
