Side mirror info required
So I got myself some JDM side mirrors early last year, decided that I should now use them on my NZ New SVX.
My OEMs are a simple "push" to open and close against the car body type. The JDMs are motor driven, using an extra button that is located in the mirror adjustment button section. I have confirmed that the JDMs work with 12V (including having the heaters built-in). But I am at a loss as to how the swivel motor drives should work anyone got a wiring diagram (or is there a module that I need). BTW I think this was NOT an option on USA models. TIA
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 03-18-2019 at 02:44 AM. |
Re: Side mirror info required
Got the wiring sorted for the swivel working - now to start on the wiring harness add-ons.
I would like to swap the glass out on one of the mirrors (it has slight salt/water damage) - does anyone know how to remove the glass from the swivel (U/D/L/R) joint ?.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 03-28-2019 at 03:30 PM. |
Let us know how you do it. Automatic folding mirrors would be make an awesome upgrade!
