#136
OBI how acurate of a measurement can you get with your calipers of these pistons from the pin to the top of the piston (not the dome/dish but the circle around the edge).
Also, how tall is the dome and what are its measurements at its top edges and what are its meaurements at its base where it meets the top of the piston? thanks |
#137
I get you measurements of the piston, Do you want it from the center of the pin or the journal.?
Tom |
#138
Or maybe I can swing by and take a look at them. I'm heading down to Miami now for Christmas with the family. I sent you a pm
#139
I'd go from the top edge of the pin hole to try to get the most acuracy. Then I'd measure the diameter of the hole. With those two #'s we should be able to make acurate comparisons. The key will be to be acurate in measuring the height from the top of the pin hole on the svx piston. It may be hard to do because of the dome and I'm hoping to get a measurement acurate one thousandth.
I just want to verify that the compression height difference is solely due to the piston so that it won't change if different rods are used. Quote:
#140
Give me a few minutes... I gotta bust out the digital micrometer and see if I can get a good measurement
Tom |
#141
From the top of the pin Journal to the top of the piston- 22.16mm
" " hump- 23.04mm doing simple subtraction the hump is .88mm At the widest point at the base of the hump- 80.78 " " top of the hump- 78.53 Hope this is all you need Tom Last edited by TomsSVX; 12-24-2005 at 09:38 AM. |
#142
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#143
OBI can you measure from the top of the pin to the top of the 2.2 piston?
#144
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
#145
#146
[QUOTE=longassname]OBI can you measure from the top of the pin to the top of the 2.2 piston?[/QUOTE
.880 inches
EG33 Turbo Porsche 914 |
#147
#148
Tom, OBI, how confident are you guys with those measurements? OBI's measurement of the ej22 piston comes out taller than Tom's measurement of the EG33. If this is correct then the SVX has longer rods or a longer stroke.
#149
#150
I am using a digital micrometer... I am pretty confident in my measurements. If someone could measure the 2.2l rod I could measure the 3.3l rod... Or just send me a 2.2l rod or visa versa. It would be best if one person could take all of the measurements with the same instruments to assure accuracy and consistancy between them
Tom |
