#121
yes I did. I'm probably going to go with leaving the open deck and taking 1 or 2 thousands off the outer parts of the deck to increase the pressure on the head gasket around the cyllinders.
pistons
Have you ever considered o-ringing?
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#123
cp
no, i don't want to go to copper head gaskets. Quote:
#124
Mike, along the lines of the pistons... Do we know the specs we are gonna have to bore the block to yet??
Tom |
#125
97mm
...extra filler to meet the required min of characters to make a post.... Quote:
#126
So when I bring my block to the machine shop, I will just tell em to surface the face and hone it out to 97mm exactly?? Just wanna be clear on this
Tom |
#127
Boring
#128
Pistons to Rods
Tom/Mike:
Do you have any idea how we secure the piston rod pins? Are we expected to use the stock circlips or are we getting teflon buttons. What type of assembly procedure are you planning? Thanks Chuck D.
#129
ya that's an easy hone..between 3 and 4 thousands...the standard step up when honing a 96.9 bore.
Chuck, as far as I know we are getting the pistons with rings, pins, and they SHOULD utylize the same circlip design
Tom |
#131
Gaskets
Check this out. I may do this instead of the copper gaskets. I have not heard back from them since I sent the gasket picture. Only problem is horsepowerfreaks are difficult to deal with.
http://www.horsepowerfreaks.com/perf...e/Head_Gaskets
#132
Chuck, the pistons are being specifically machined to use the factory circlips. I don't know if you've taken an engine apart yet or not but it's impossible to install the pistons with any other circlip.
Mike, wadya think of those gaskets... I think they will be better than stockers
Tom |
#134
I can't say that I know really.
Asside from not knowing if they are better or not I would ask cometic a bit more. .065" compressed or uncompressed? Why a 98mm bore? I know I measured my used gasket bore to be 98.75. Might want to measure the diameter of the chamfer on your cyllinders and compare to the gasket bore. Quote:
#135
wasn't this thread about camshafts?
and as it just so happens looks like we will be able to take the cam orders next week |
