Old 03-09-2007, 11:39 AM
trieck1232 trieck1232 is offline
Send a message via AIM to trieck1232 Send a message via MSN to trieck1232
Crunching noise...
Hey all! need some more advise... I'm getting crunch sound from the front left (drivers side) wheel area, can't figure it out, it isn't consistent but seems to do it if i go over a bump or when i turn left, its not a CV joint sound i know what that sounds like
---Travis---
Old 03-09-2007, 11:47 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I would check your shocks to see if the additional pressure from bumps isn't causing the sound. Also check for wheel rub, turning and speed bumps could cause that.
Old 03-09-2007, 02:36 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
no way to check the shocks without taking it all apart. the bounce test doesn't work - for this car it seems. you can do the bounce test and think your struts are good but they are actually shot. i've tried before i changed out the struts on my car. i thought they were ok. but they were completely shot.
it could also be the link rod. when i had the car for the first few months, i was getting noise, particularly when i went over bumps. it turned out to be the link rods
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 03-09-2007, 04:54 PM
2NI's Avatar
2NI 2NI is offline
Send a message via MSN to 2NI
I have the same questions on my mind... Are my shocks dead or not??? The car has 144000 miles on it & my friend who runs the Subaru garage said "NO" this afternoon & even told me that except for putting on aftermarket products like Tein or whatever, he never changed any shocks on any Subaru!!! Oh yes once he told me, on an Impreza... But with almost 400000 kms on the clock!!!
So WTF??? I keep on saying that they're dead because of all the noises I hear when I pass a bump (even a small one!) or get in a hole... And my friend says no, it comes from the ****ty Pirelli tires that are on & seem to have a rubber made of reinforced concrete!!!
He suggests to try another set of tires, something more tender like Bridgestone or Michelin.
What do you guys think? I only own the car for a few days and I'm kinda surprised by the way the shocks are working (or better said not!)... I taught that on a US Spec car like that it should have been something more chewing gum than hard-rock, loool
Thanx.
Beast from the East
Old 03-09-2007, 05:16 PM
really..the only way is to take the shocks off and take the spring off..that is the guaranteed way to find out. it will cost you money. but i am only telling you guys out of experience. if you dont find it valid. it's your choice
Old 03-09-2007, 06:55 PM
hmmm well hmmm its all but stoped now, this all started when i did my brakes this morning the link arm is the realy tiny one connected to the sway bar? the bushing does look worn...idk i did see on ebay a set of oem struts for 200 bucks bamie ill do that...
---Travis---
Old 03-09-2007, 07:47 PM
but are the struts good? it's really hard to buy things like that...i just went and spent the money on brand new struts
Old 03-09-2007, 07:50 PM
i just saw the auction...never noticed it before...it looks good - if it's legit.
Old 03-10-2007, 12:59 AM
yea...i knwo to good to be true almost/..
---Travis---
Old 03-10-2007, 01:46 AM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
the car has 144000 miles on it & my friend who runs the Subaru garage said "NO" this afternoon & even told me that except for putting on aftermarket products like Tein or whatever, he never changed any shocks on any Subaru!!!
Hmm.. I think that's non-sense. I replaced the back struts on my legacy wagon, after a few years of hauling lots of stuff in the back. It had around 200,000 on it.
Also, when I got my Pearl, the front struts and mounts were completely shot, I mean, I did not want to drive it anywhere and the front tires were totally scalloped and cupped, it was scary.
It's usually easy to tell when your struts are bad, You'll get a nice rattle when you go over a bump as the spring rebounds. Also, look closely at them and see if you can see where any oil may have leaked out.
Old 03-10-2007, 06:12 AM
when i first got my car. i was told that the back passenger side was gone because of signs of leak. the other three had no signs of leak but were also gone
Old 06-20-2007, 07:41 PM
Earthworm's Avatar
Meow!
The rear struts on mine actually failed the bounce test...badly. That was my main reason for going with the Koni/GC combo.
