Sunroof Gasket -- This isn't right, right?
Dumb, quick question... I just got my car back from a body shop who fixed some cracking paint on my roof. Understandably, they had to remove the sunroof gasket to paint, but it looks to me like there is a piece of the gasket broken or missing?
Can someone just confirm for me that there shouldn't be that gap in the middle? And if so, what is SUPPOSED to be there? Its something I never took notice of... Thanks in advance! -Dan
Dan Taney 1996 Subaru SVX LSi (Red) 2019 Subaru WRX LTD |
Re: Sunroof Gasket -- This isn't right, right?
No gaps in mine at all....
Ok... thats what I thought. Thanks! Does anyone know if there is like some small piece that is supposed to join over the two ends of the gasket or anything? All I can guess is that either a piece of the gasket broke off or there was some coupler piece that they didn't reattach... any thoughts?
Rubber is flexible, maybe they reattached the gasket not making enough tension so the rubber goes all around the sunroof line.
95´ Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe |
When I had mine off to repaint my roof a couple years ago I ended up with a similar gap when I put it back together. I took it back off and stretched it a little and put it back on. Then the gap was mostly gone. There isn't anything else that goes in there.
Ok, thanks for everyone's input. I am just going to take the car back to the shop tomorrow and have them attempt to fix it. This way if anything gets damaged in the process, it won't be on me
the seam in the rubber should be at the back of the sunroof, too. Not the front.
My pearlie had a gap in the sunroof rubber (about 1/2") when I bought it. When I had the sunroof panel repainted, the shop took the molding off. When they reinstalled it, they also stretched in so that it actually overlapped at the ends. After they installed it the rubber was compressed at the ends and has never moved, maintaining a perfect seam with no gap. The same with my polo Do this in warm weather or use a heat gun or hair dryer to soften the rubber a bit to make it more pliable. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-05-2010 at 07:50 AM. |
