New SVX Owner
I just picked up Meangreen95's 1995 Polo Green LSi. It's a really sweet ride! I need to clean it out really well and it'll be ready to go.
That is a nice car. Put some pictures up that show it after you get it claeaned up. Nice it could be kept by a member here.
Already have a slight problem though - the key won't turn in the lock on the trunk. The opener will open the trunk and the key will open the doors and the ignition, but it won't open the trunk.
You lucky b***ard!
Congradulations...That car is quite nice. I was lucky enough to ride in it in person. you'll have to post some nice wash and wax pictures P.S.-That drivers visor is NEW
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
Isn't there one key called a valet key that will only let you in the car and to drive it, but won't open the trunk? You might have that one. There should be a master key that opens/starts everything.
Cyn 92 Ebony Pearl LS-L 199,000K New Tranny (my DD) 89 Chevy Sprint (for when my baby's in the shop) 05 Mazda 3 (Hubby's DD) "You win some, you lose some, you wreak some." Dale Earnhardt |
Here's some pics: http://gallery.discens.org/main.php?g2_itemId=241
Perhaps the lock went bad and he got a replacment one. Then you'd need to have a new key cut for it, which, if he didn't do, or did but forgot to give you, you wouldn't be able to get in the trunk.
Just a thought. I've never heard of one with a problem in that direction, just the other one (latch won't relase trunk but key will). In those cases the cancel switch is generally the culprit.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
This is common enough, and is not a major problem. What has happened, the lock has frozen or is stuck basically from all the muck that gets in there over the years. You know the amount of road grit and salt that gets fired up on the tailgate in winter. This happened my Black Betty, and I had to free up the trunk lock and the passenger lock as they both stuck. What you do is get a can of penetrating oil, or WD 40 will do if you have that. Push the key nose barely into the lock. Squirt the oil past the key into the lock. Then push the key half way into the lock. Squirt the oil along the blade of the key so the key is plenty wet. Now push the key fully in, and wriggle it right and left. You will see it starting to make movement, getting more distance right and left. If it feels stiff, don't force the key. They are made from brass and will snap if too much pressure is exerted. Repeat the oil process, and wriggle the key some more. With patience it will free up. Joe
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Thanks Joe - would Lithium grease be useful at all? I got some of that at Autozone today to help out my noisy doors and slow sunroof.
::EDIT:: WD-40 did the trick. The lock is unfrozen. Thanks again Joe.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 08-18-2007 at 03:34 PM. |
Good work Jason. It only needs keeping it freed up now. The trunk gets the least use of the key because most of us open it with the lever beside the driver seat. That's one of the reasons it sticks. What crazy said is also correct. All that oil you put in there will attract a load of dust and dirt. Give the lock plenty of use with the key so it is really free. Let the WD 40 "dry" off or run off it for a few days. When you have it dried up well, use a puffer pack of graphite to get into the lock tumbler. That will keep it free and slippery without attracting dirt. Lithium grease is too heavy. It is wonderful for sunroof runners and so on because you can access them to smear the grease. It is not suited for locks really, no penetration. Joe
Congratulations on the Polo. I'll keep an eye out for it on Rt 15.
Joshua 92 Ls-L pearlie 73,000 miles |
