Old 02-11-2008, 03:48 PM
Mr.EG33's Avatar
Mr.EG33 Mr.EG33 is offline
Question Will a 1997 Subaru Outback, Legacy Manual AWD Transmission work?
Hello all
Ok so I found a killer deal on a MT and just would like to know what I need to complete this swap if its possible... I really want a MT in place of my 4EAT; any and all help would be great...
Thank,
Mr.EG33
*1992 SVX LSL 134,000mi 3.3
*1968 Olds Delmont 88 Conv. 58,000mi 455ci v8
*1995 Pontiac Firebird 172,000mi 3800
*1995 Pontiac Bonneville SSEI 78,000mi 3800 S/C
Old 02-11-2008, 03:52 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Yeah, the trans will work. You'll also need the rear diff out of that car. If the diff isn't available, you'll need to get a 4.11 diff out of a Legacy.
You'll also need to fabricate a crossmember, shifter linkage and pedal assembly. Or you can contact TomsSVX for the fabricated bits.
Old 02-11-2008, 04:21 PM
Mr.EG33's Avatar
Thx for you fast responce Hocrest
OK so my axels are fine? Also what about the drive shaft? Tom if your out there I need your help with the parts that Hocrest said I need....
Thank you,
Sean (Mr.EG33)
Old 02-11-2008, 04:26 PM
Hocrest's Avatar
The front axles are fine. The rear diff will be converted to use the LSD kernal out of your SVX diff, then the rear axles will work.
The driveshaft also need lengthened, or you can modify a driveshaft from a 5 speed Legacy.
Old 02-11-2008, 04:39 PM
Mr.EG33's Avatar
Ok Im a lil lost on this part
So is my gear ratio going to stay the same? Will my SVX be faster?
Thank you,
Sean
Old 02-11-2008, 04:46 PM
Hocrest's Avatar
The stock SVX ratio is 3.545, the Leg is going to be 4.11.
If you swap the trans without the rear diff, the front diff will be 4.11 and the rear will be 3.545. There are directions around here to convert the rear diff. I think there is a link in SVXfiles signature???
Old 02-11-2008, 05:16 PM
try searching this kind of stuff... Also there is a link in my signature that comes in handy
