EGR question....
I removed my EGR tonight, blocked off the port on the rear, pass. side of the manifold. I then blocked off the port on the exhaust manifold. My question is this, are the two 1/8" hoses that run off the top unit of the EGR the hoses that run up to the throttle body? If that is the case then I will just be tieing those two openings togethr with a single piece of 1/8" hose....
Re: EGR question....
You may be able to replace the sensor with a resistor that will signal that is is working. I don't have that sensor on my model, so I can't say what the 'hot' resistance is. Harvey.
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
The 1992 US models did not have temp sensors either, unless they were fitted to meet California standards.
This does not mean that it will not throw a code for a fault in the EGR system. Somehow or another, the ECU can still throw a code (EGR stuck open or closed) even if the ECU wasn't programmed for a temp sensor. Regardless of that, Bobby, you can cap or join the two fittings on the throttle body to keep them from leaking. Tom |
Tom - I'm still throwing the code 56, came up about 10 miles after you left.
Can it be something besides the EGR, or do you think despite your heroic efforts to clean it, a new one is in order? Or sounds like maybe I can ditch it too, but would that mess me up for possible future emissions passing? Would love to finally have no check engine light!
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Tom |
why would you do that what do you gain
