Engine options for SVX?
I am searching for the best engine options to do a swap in my SVX.
I know the best would be to keep my EG33 engine and fix it, but could'nt find the parts to fix it (crankshaft, a head-corroded due to storage underwater -, gaskets, etc), so i am going to sell the working bits of my engine and use that money to acquire another motor. I was thinking in a EZ36 or EZ30, or maybe a four cilinder. I had this car for 3 years now and i was'nt able to fix it yet, so i am starting to think in non standard options, and to weight the easiest ones. I wonder if my current ECU and stuff could make a EZ30 or 36 engine work . I want to see it on the road!
95´ Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe |
Re: Engine options for SVX?
no, no and no.... any other swap will require a full harness and ecu swap. and will thusly require a mt swap unless using a capable standalone suchas the hydra. getting another eg33 will prove to be me cheaper and less involved than any other option.
The simple answer is no. To do an ez* swap, youd need the engine, harness, and ecu for the donar motor. Then you get into all the immobilizer, and drive by wire stuff. The 2000-2002 ez30 is the best bet for an ez swap. Been done on an xt6. If you arent up to a harness swap, your best bet is a replacement engine.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
The wiring thing should be no prob, just more time and a lot of work. What about 4 cylinders? Easyer to get, the only problem being the low torque compared to the original engine. Maybe turboed 4 cyl can get close to those values, but still more inclined to a 6 n/a. Last question, how much should i spend in a cheap (and i mean CHEAP) wonking EG33, taking on count that the cost is, the engine + alot of money for shipping to south america.
When I posted the original post, I was on my phone and did not realize you are in South America. If other Subarus are more common down there, it may be better to try and put in a different engine since replacement seals, gaskets and other parts may be more readily available. What is wrong with your current engine? |
I wonder how heavy the EG33 is.
Have you ever done a full swap? I have and it's not something I'm anxious to do again. It is a lot of work.
I've got a crank, head and connecting rods that I'm willing to sell. You can pick up a gasket kit for about $250, bearings for $80, and rings for $100. It would be cheaper in the long run to rebuild or replace your EG33 than it would be too swap in an EZ. Just my .02.
'94 SVX '92 SVX |
I'll send you a PM later. We might be able to work something out. |
