How to remove waterfall grille?
How do you remove the waterfall grille?
A pair of needle nose pliers. You'll see 2 places in the top side of the grille under the hood where you pinch the tabs with the pliers and pull forward on the grille while doing so.
Once you get the hang of it...it takes like 10 seconds...very easy to do...good luck
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD* 2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp). Charlottesville, VA Represent! (voted #1 place in America to live!) http://www.subaru-svx.net/photos/user.php?Amazonparrot |
You will first want to use a screw driver or other pointy object to push down the horizontal tabs on the grille side of the clips. After these are down you can gently pry the top of the grille away from the top radiator mount. The clips will stay with the grille and just remember to return the horizontal tabs to their original position before reinstalling.
lift and pull, thats how my 97 grill comes out
98 Impreza Wago-O-Doom & Datsun Roadsters |
Discovered that the '97 grille has different tabs. They're quite a bit shorter.
